cold start issue. engine sounds like its not running all cyl's
  • EMU_S2
    • Oct 2013
    • 90
    • Country: Denmark
    Hi there.
    Im having a little issue with my 3B s2.
    Opun cold starting. Especially in cold weather. Its hesitating very lightly wen starting. But thats not the primary problem. Once its started. It sort of sounds like not running on all cylinders for 20-30 seconds.
    Any good calls here?
    ill try to make a video of it later.
    Rgds Chris
    Unplug and re-plug the MAF a few times, see if that helps.
    • EMU_S2
      • Oct 2013
      • 90
      • Country: Denmark
      Running without maf. Speed density tune.
      • mike74
        • Apr 2014
        • 615
        Distributor cap/HT leads?
        • Monkeymagic
          • Mar 2012
          • 3419
          Fuel pressure would be my bet
          • EMU_S2
            • Oct 2013
            • 90
            • Country: Denmark
            Distributor is old. But the cap is new. Ive ben thinking of the distributor aswell. Not sure why. But it seems like a little oil finds it way into the distributor aswell.
            • Monkeymagic
              • Mar 2012
              • 3419
              I have known oil contaminate the Hall sender and cause problems
              • simons2
                • Mar 2010
                • 344
                Iirc if the distributor body is in the wrong position it will allow oil in
                • EMU_S2
                  • Oct 2013
                  • 90
                  • Country: Denmark
                  Whrong possition? It should be adjustable? :\
