Help with what feels like a misfire
  • CoupeWannabeS2
    • 403
    Was wondering if anyone could comment on an issue i'm having with my ABY.
    It started to run rough, and felt like it had a misfire. Strangely it made the car sound a bit like a Subaru Impreza - presumably because of the apparent misfire. I limped it home - and noted that it wasn't wanting to accelerate very well at all. Also the engine seemed hotter than normal when I parked it up, and considering I carefully drove it home.
    A few days later I had the chance to pull the fault codes, and had the following:
    00516 - Idle speed switch
    00537 - Lambda sensor control
    01250 - Injector Cyl 2
    01251 - Injector Cyl 3
    01252 - Injector Cyl 4
    01253 - Injector Cyl 5
    I then cleared these codes, then started the car and the engine appeared fine. I took it out for a run to replicate the apparent "misfire fault" and see what the fault codes were at that point.
    After around 10 miles it started the apparent misfire again. The only code I got from the car after this second time the misfire presented was 00537 - Lambda Regulation 08-10 Control Limit Surpassed - intermittent.
    I note that the code 00537 can be due to several things such as:
    -Fuel tank empty at least 10 litres
    -Fuel system pressure too low
    -Failure of spark plugs, ignition coils
    and ignition output stages
    -Ingress of air to G70
    -Leak in exhaust system up to catalyst
    -Faulty lambda probe
    -Fuel system pressure too high
    My first question is do the earlier codes and symptoms described give more of a clue as to what the problem might be?
    I was thinking of disconnecting the Lambda, and then seeing if the fault returns or not. Does that seem sensible?
    My logic being if its a faulty Lambda then I wont get the Misfire back, as the car will be on factory settings. If the fault comes back, then I continue to look for other causes.
    Any comments welcome.
  • freakytate
    • Jun 2014
    • 206
    hi, i may stand corrected but if it sounds like a subaru id say it possibly missing on 2 cylinders especially when you say no power at all. im new to the s2 scene but using i think it may point to a pos unit that fires the two?
    my lambda goes intermittent but just idles rough and lower mpg, ive also had idle speed switch fault which gave none of your symptoms
    • andyg plym
      • Nov 2006
      • 4646
      Maf sensor is my bet, these faults sound very similar to mine, I replaced the maf even though vag com didn't throw a maf code and it fixed it.
      Was chasing this fault for ages
      • rynaqui
        • Mar 2012
        • 2752
        • Country: Malta
        Probably MAF as above, it probably starts to misfire a bit after startup correct?
        1996 S2 ABY Silver
        • CoupeWannabeS2
          • 403
          Thanks everyone for the input.
          I will focus my attention on the MAF sensor.
          The first time it started the misfire was about 5 minutes after starting the car, and the second time I noticed it about 20 minutes or so later.
          Can you un-plug the MAF and get the car to run with some sort of factory settings? Just thinking to confirm if thats the problem, and so I can use the car for the time being?
          • freakytate
            • Jun 2014
            • 206
            Can you run with maf unplugged like my golf tdi?
              Injector harness wiring would be my first suspect
              • 220bhp
                • 2578
                • Home: United Kingdom
                Dan I have a spare maf you can try.
                • CoupeWannabeS2
                  • 403
                  Hi Lou, that would be great - I will drop you a private message.
