Thicker Head Gasket
    Thicker Head Gasket
    Where can I get one from? Want to reduce comp ratio.
    Anywhere in UK??
  • andy10v
    • 5996
    2 OE headgaskets with ARPs?
    Sold ABY-stock
    • 220bhp
      • 2578
      • Home: United Kingdom
      John I used two Victor Rienze metal head gaskets. drill the brass rivets that hold them together And use both the middle sections, and the top and bottom outer layers from one of the gaskets.
      I used stretch bolts. Its held for two years now. ARP bolts would only make it better.
      Doug at MRC told me how to do it
      • SteveH
        • 4460
        You can buy a thicker laser cut middle section if you don't want to use two Reinz pieces. What's the benefit of splitting the gaskets over just sticking one whole gasket on top of another. I'm planning on doing the same thing to reduce my CR.
        Compression ratio * Series * - 1,6 mm Ebay ID 190358824584
        Compression ratio 8,92 : 1 - 2,1 mm Ebay ID 191060500491
        Compression ratio 8,57 : 1 - 2,6 mm Ebay ID 201031744161
        Compression ratio 8,25 : 1 - 3,1 mm Ebay ID 190390605076
        Compression ratio 7,96 : 1 - 3,6 mm Ebay ID 201031749962
        Compression ratio 7,69 : 1 - 4,1 mm Ebay ID 190725315258
        Compression ratio 7,44 : 1 - 4,6 mm Ebay ID 191060554366
        Compression ratio 7: 1 - 5,6 mm On Demand
        91 Modded 3B
        14 A6 Avant Black Edition
          Don't 034 do them?
          • SteveH
            • 4460
            Originally posted by Rusty
            Don't 034 do them?
            Probably and I bet expensive. Sourcing from Germany would be far better for EU folk. The e-Bay items are cheap if you only want the centre section and plan to use your own outer sealing layers from an Reinz or similar gasket.
            91 Modded 3B
