I have an idea for my Ur quattro, By making more power by using a block for a audi a6 c4 2.5 tdi and using a 20v head from a 3b engine, would that work or not?
Cause i wanna fix up the car in the summer time and have ideas of what to do to it.
In the last years of Urq production, Audi installed the "RR" engine which basically the same as the 3B that was in the first years of S2 coupe production (remember that there is an overlap). The use of 2.5L AEL C4 Tdi or Eurovan diesel engine is a common way to get a stroker engine for people with 3Bs, AANs, ABYs or ADUs so yes it will work.
Problem areas that you will need to address include the intake and exhaust systems, the radiator situation, ignition system (you would be better off to use an AAN or ABY head so you can use the five coil ignition system), and of course the ECU (3B or RR ECU for the 3B head or AAN and ABY ECU for the AAN/ABY head).
You better have a good budget available to sort all those.
Good luck
Good luck
Couldn't i use the AEL? i got a AEL block and i have a 3b engine, but isn't the AEL better than the AAN? or is that the AAT one of the two haha
