Those who run LPG converted 2.2's
  • diesel des
    • 3896
    #481
    The pressure will drop slightly but should still be liquid at that point. If it's vapour then it's expanding some place and that could be a restriction.
    • hunker7
      • Mar 2014
      • 3487
      #482
      I did add a rubber pipe at the end which is higher ID so I can point it away from the car, so that could explain that?
      '93 Audi UrS4 Avant
      '15 Audi A7 quattro 3.0 TDI
      • hunker7
        • Mar 2014
        • 3487
        #483
        Would a failed DV mess with LPG?
        '93 Audi UrS4 Avant
        • hunker7
          • Mar 2014
          • 3487
          #484
          ..or an air leak? I'm also thinking of pulling multivalve and checking for blockages, doubt it, but don't know what else to look at. Then again what could be blocking it? if there was a blockage, would pressure at reducer drop when it goes lean?
          '93 Audi UrS4 Avant
          • diesel des
            • 3896
            #485
            Yes pressure would drop
            • hunker7
              • Mar 2014
              • 3487
              #486
              Pressure doesn't go below 1 bar under boost. So there are no problem upto the inline sensor?
              '93 Audi UrS4 Avant
              • diesel des
                • 3896
                #487
                Yep. Has the Motronic reduced it pulse time?
                • hunker7
                  • Mar 2014
                  • 3487
                  #488
                  I will go out tonight and get dad to see what happens with lpg times and petrol times, as they should be about the same shouldn't they?
                  '93 Audi UrS4 Avant
                  • diesel des
                    • 3896
                    #489
                    Yes Motronic times should be the same on Lpg and petrol.
                    • hunker7
                      • Mar 2014
                      • 3487
                      #490
                      I'll go out and check, then report back
                      '93 Audi UrS4 Avant
                      • hunker7
                        • Mar 2014
                        • 3487
                        #491
                        Here is a video of the injector times. stops at 12ms and just doesn't increase.
                        '93 Audi UrS4 Avant
                        • diesel des
                          • 3896
                          #492
                          Increase the part in your map with a point near 14ms on petrol and 12 on gas. Add 10% and test
                          • hunker7
                            • Mar 2014
                            • 3487
                            #493
                            So that would be the 12.9 point in #468 on page 32?
                            '93 Audi UrS4 Avant
                            • diesel des
                              • 3896
                              #494
                              Yes both the 12.9 and the 14.3 points
                              • hunker7
                                • Mar 2014
                                • 3487
                                #495
                                OK it's about the same now. Increased both points by 15% but still goes lean? Ms are about the same for both at the point where it stops.
                                '93 Audi UrS4 Avant
