Those who run LPG converted 2.2's
Petrol seems to be on the rich side too now that I had a look. 3rd gear and it goes to 0.76 Lambda. PRJ have said in other thread anything less than 0.78 you loose power massively. So maybe that's why it's been messing with LPG too?'93 Audi 100 Avant - R.I.P
'93 Audi UrS4 Avant
'15 Audi A7 quattro 3.0 TDIComment
Hello i Am new here and i Am sorry for my bad English
But wen the presure raises in the Intake you get negatieve presure against te lpg injectors
Can that reduce lpg flow to te intake ?
Like petrol for each bar boost the fuel regulator raises 1 bar
Maybe i Am totaly wrongAudi 100 2.3 URS4 2.2T aanComment
Maybe. Now the Lpg times are greater are the Lpg mixtures ok? Try cleaning the maf?
Sent from my LG-H955 using TapatalkComment
The Lpg pressure also increases with boost like petrol does so no problems there.Hello i Am new here and i Am sorry for my bad English
'93 Audi UrS4 Avant
Then you need to increase the multi. This is a basic scaler
OK. I went a bit violent with the multi but it's definately helping. It is extremely rich at idle now and too rich at WOT as it starts shaking pretty badly. So I guess now I can just adjust each point separately to get it running right?
Last 3 points are now into 20ms last one being 29ms.'93 Audi 100 Avant - R.I.P
'93 Audi UrS4 Avant
Try a compromise multi as this will reduce the amount of tweaking the graph points need.
I'll get dad behind the wheel tomorrow night and go for a drive on M25. I've now adjusted the idle and that's stoichiometric now, I'll leave it as it is for now.
What could cause for it to go that badly? She was running fine before
'93 Audi UrS4 Avant
I'm not sure. The Lpg system can take a while to bed in the injectors and such but if it's running odd on petrol too maybe there is another issue?
I've noticed idle on petrol is slightly lean occasionally so I'll get a compressor off my mate and get it properly tested. Now that it's adjusted I must say it's running much nicer than it did before ir started to not work at all, so possibly it's been getting worse with time and I just didn't notice till it went completely bad. I don't look at aft gauge all the time.'93 Audi 100 Avant - R.I.P
'93 Audi UrS4 Avant
