mfts help please
  • freakytate
    • Jun 2014
    • 206
    mfts help please
    My temp guage is barely creeping over 55'c. Fan kicks in etc and heater warm but gauge not climbing. I would like to put it right for when my dials come back.
    Is there an easy mod to adapt or use 3 pin newer version on my aby s2? 3 pin mfts are cheap and readily available. Such as ebay item 181652396025
    cheers
    3 pin is the new 4 pin.
    i.e. they don't make 4 pins ones anymore, but the 3 pins one will work.
    Can't recall if it is this MFTS sensor is the one that controls the temperature gauge or the one at the back of the block.
    Others will advise shortly.
      F76 Multifunction Temperature Switch info
      MFTS info (for the temp gauge): http://forums.quattroworld.com/s4s6/msgs/22584.phtml
      G62 info (coolant temp at the back of the head for the ECU): http://forums.quattroworld.com/s4s6/msgs/20985.phtml
      All found here (click on the labels):
      • freakytate
        • Jun 2014
        • 206
        So the new 3 pin is nust olug and play,? Where can i get a behr or jp one? Not much on googles
        cheers Lads
        • Michael S2
          • Dec 2011
          • 1378
          Quattro Corner one is behr I think. Yes plug and play. There's a good chance the connector will fall apart in your hand when you remove it, these are available from Audi.
          1995 Audi S2 Avant
          • Rikki Kitto
            • Feb 2010
            • 6276
            Might have one or two spare ya can try I'll have a look in the black hole (shed)
              Yes, sorry forgot to mention this. Well worth doing. All of us should do this especially when you see and hold a new one beside an 18 year old one.
              Well called.
              • freakytate
                • Jun 2014
                • 206
                Cheers lads. Connector is fine had it off yesterday.
                rikki ritto that would be great if you wouldnt mind. Thank you
                • Rikki Kitto
                  • Feb 2010
                  • 6276
                  PM me your address
                  • andy10v
                    • 5996
                    Thermostat is ok?
                    Sold ABY-stock
                    • freakytate
                      • Jun 2014
                      • 206
                      New stat on hEr but have contacted guy and he sending me a priven one. Its odd sometimes uphills or bends or even bumbs it sorts itself out but then back to low. Also rpm guage is dropping to bearly zero but i have non s2 clocks in at moment as my dials are knackered. My temp previously slightly high and would fluctuate. Fan kicks in a lOt. I have aux rad deleted but cant see that doing much difference in this weather. I have nissens non aux rad on too which is slightly smaller but i cant see that effecting so much. I want a steady 87'c so i know shes at her best efficiency and ecu is not in warm up mode etc
                      • mike74
                        • Apr 2014
                        • 615
                        Do you still have the little rubber boot around the MFTS & connector? If you don't and have removed the aux radiator then cool air passing over it could be affecting the readings you're seeing...
                        • freakytate
                          • Jun 2014
                          • 206
                          Yeah still on it and cleaned out yesterday
                            Do you have the autoclimate control system?
                            • freakytate
                              • Jun 2014
                              • 206
                              unfortunately not but i have got vagcom and can monitor engine coolant temp but im not sure where that signal comes from
