I have all the parts to build me a stroker, accept the front harmonic damper. What damper do i use for an stroker? The diesel damper, the pertol damper? Can you stroker guys give me a pointer???
Stroker
Tags: None
Tought, i would use an AAN for more space for ic.
basically You could use any damper you like?? Right?Comment
is it the secret into which car you gonna put this AAN ? as I already posted depending on pulley you will need all brackets for your auxiliaries from the same engine as your pulle, and yes, you will gain more space for IC with AAN pulley because it uses one belt for all auxiliaries and all are shifted a little bit back which can cause some other fitment issues.Comment
