Hi,
I bought an AAN engine from a not starting project, golf2r32 member. And I have the same problems like him...no spark and fuel from the injectors, but I have +12 in the connectors
I checked all positives and grounds, hall, speed & firing point sensors....the ecu connector with the ecu pluged, I have all the signals but I can see the shape because I'm still waiting for a osciloscope
The ecu works fine in my s2, starts the engine
The wiring loom for my project has inmo, may I need to do something with this connector or leave it alone??
And my question is if the timing is out, does the ecu cuts fuel and spark??
Thanks, thanks, thanks!!
and I think that the ecu control the injectors duty by ground not with positive.....
