Oki starting to really dislike my car.
Well cars is running real crappy.
1. idle is going up and down.
2. when pressing the clutch and changing to neutral engine sometimes stalls.
3. when pressing the speeder in 2. gear from perhapos 1200 rpm it hestitates and there seems to be more smoke comming out.
4. Fuel consumption is high, 6.6 L/KM normaly it is around 8 L/KM
So far from reading i can try to clean ISV and MAF, using IPA. Lamda sensor was change 5 months ago i think, so that should be fine.
I will try to get the local stealer to pull the fault codes and post them here.
If MAF is ****ed, will try to do s2central guide on meassuring and the burn stuf.
Where can i get a MAF cheapest? Seems audi want 320 euro for a new one.
Any other suggestions on things i should try?
/Jonas R.
/Jonas R.
