well finally my E85 project is complete on my ABY S2.
I will list the progress to date:
Stock engine
7a cams (intake and exhaust)
Wagner Reverse Intake
Wagner Intercooler
Wagner Evo Exhaust Manifold
GT3071 0.63
Bosch 1600cc injectors
Bosch 044 in tank fuel pump
E85 fuel
EMS standalone ECU
Innovative SCG-1 boost controller
FSI Coil conversion
Converted to run a dizzy purely for the hall sender and cranking but not for spark (easier to tune for EMS)
Result:
295kw atw @ 6500
520nm atw @ 4000
25psi
Im very happy with the result as the power curve is very linear and keeps pulling all the way to redline so i reckon it has a little more in it if i bump up the boost to say 30psi. But for now i will run for a while at 25psi to see how she goes
However on purpose i have had it tuned so the boost onset isnt too early down low so not to bend rods.
So at the moment full boost isnt until 4000ish which makes it a bit of a lag monster, however im scared to have it come much earlier than that at least not until i go next step and do internal upgrades
What are peoples thoughts on earlier boost onset for stock internals or more so the above amount of torque but at say 3500?
Stock engine
Wagner Intercooler
GT3071 0.63
E85 fuel
EMS standalone ECU
FSI Coil conversion
Result:
295kw atw @ 6500
520nm atw @ 4000
25psi
