Stoker from an AAB?
  • pnanassy
    • Dec 2004
    • 287
    • Country: Hungary
    Stoker from an AAB?
    Hi !
    I just want to ask,that is it possible to build a Stroker from an AAB bottom end?As i know it is from a 2.4 D T4.
    Thanks,
    Peter
    Peter Nanassy
    Custom Engine Management,and Electronic Fuel Injection solutions supplier , contact me for details.
    http://www.carstyling.hu/car_shower.php?id=19845
    http://www.youtube.com/watch?v=FYOVA_285Rs
  • porkkis
    • 1994
    It seems to have the oil squirters so why not? Can't imagine a difference between AAB and the turbo diesel blocks.
    • caterpillar
      • 2480
      yea! BUT: THE AAB block are only 79,5 bore... 2,5dti are 81mm bore.but the cranck are 95,5 like the AAT 2,5tdi verson;BUT the cranck havent the same P/N....I havent checked out the deckheigth,i think its the same as 2,5tdi...236mm. i have NOT checked out the sylinder THICKNES,may it be thicker than the 2,5tdi.dont know that. i have sutch a engine, i will tell the forum later on about the AAB 2,4 diesel....
      • porkkis
        • 1994
        Isn't it just better that it's smaller bore so that it can be bored to factory spec for 81mm pistons? This way it's "new" to start with. I'm almost 100% sure that the cast is the same.
