What size -AN fittings have people used when replacing the OE turbo oil lines?
I recon the ID of the oil feed pipe is 10mm and the drain must be 19mm. I've read a few posts and I'm not 100% sure whether the -AN number is the OD of the pipe or ID
I'm after some weld-on fittings to use the original flanges but want to make sure I get a size that's not going to restrict flow in or out.
