Turbo oil feed and drain -AN hose/fitting sizes
  • SteveH
    • 4460
    What size -AN fittings have people used when replacing the OE turbo oil lines?
    I recon the ID of the oil feed pipe is 10mm and the drain must be 19mm. I've read a few posts and I'm not 100% sure whether the -AN number is the OD of the pipe or ID
    I'm after some weld-on fittings to use the original flanges but want to make sure I get a size that's not going to restrict flow in or out.
    91 Modded 3B
    14 A6 Avant Black Edition
  • jsws3
    • Apr 2012
    • 1174
    On my precision turbo it's an4 feed and an10 drain .
    • SteveH
      • 4460
      Thanks. I'm still using a kkk, but that gives me an indication of the size of the return hose into the block.
      91 Modded 3B
      • terrybullwon
        • Mar 2006
        • 8782
        I would use a -12 or -16
        Chef
          The bigger the better on the drain, I'm using -12
          I don't think you can over supply oil to a journal bearing turbo, -4 seems the norm but you could go -6 to be the same as OEM
          • SteveH
            • 4460
            Cheers! Ordered my fittings and just need some decent braided hose to make up the pipes.
            91 Modded 3B
              Where did you get your fittings from Steve?
              • SteveH
                • 4460
                eBay!
                Hosefittingsuk
                http://www.ebay.co.uk/usr/hosefittin...72.m2749.l2754
                91 Modded 3B
                  Cheers Steve - how are they quality wise?
                  • SteveH
                    • 4460
                    I will let you know when they arrive....
                    91 Modded 3B
