I have started to mount a rs2+ kit from 034 on my 90q but ran in to some truble with the injectors.
standard oem clips dont fit,I asume that I need some that are dubbel the hight, that they are there for a reason and are needed?
Anyone know where I can get som clips that will fit?
stock on left en new on the right.
I think most people run them with no clips and just relay on the fuel rail being bolted down to hold it together. That's what I did when I had them. Not ideal but...
haha yes they are not the most reliable supplyers sometimes it seams.
oki I'm shure it's fine without them it's just that if its not it can be really bad.
If im not comletly of the injectors are oem on some volvo's so thats i lead worth checking on atleast.
thanks for the respons guys!
Same thing with the long EV14s. If you have a stock manifold it's fine without the clips, with the Wagner they drop right through though, I put them in the lathe and cut a groove in the right place for the stock clips
