Got 8 fault codes on newly built engine, help please.
  • k.alle
    • Feb 2008
    • 801
    My burn damage is starting to heal so now I'm starting to focus on the car again.
    Does anyone have the part no for the plastic "T" piece that broke on the return hose from the matrix?
    I don't have Kate with me unfortunately.
    Also, where's the best place to get a main radiator from?
    Audi S2 -1994 | 480 Hp 650 Nm | FlexFuel | MaxxECU | 3" Stainless | Porsche GT3 Front Brakes
    http://www.garaget.org/?car=52877
      Climate control coolant Tee PN with Coolant Temp Sender, O-ring and clip PNs and more
      Originally posted by k.alle
      My burn damage is starting to heal so now I'm starting to focus on the car again. Does anyone have the part no for the plastic "T" piece that broke on the return hose from the matrix?
      Hope your d.I.c.K. has healed.
      That climate control T is PN 4A0819497. It is the same as the one used on the LHD C4 UrS4/S6 with the automatic climate control. The RHD "T" is integrated with the heater valve, PN 893819809.
      893819809:
      • k.alle
        • Feb 2008
        • 801
        Thanks UrS4boy, that is exactly what I was after.
        Helpful as always!
        Yes, my d.I.ck has healed nicely, it is my right thigh that's still needing attention.
        Oh well, at least it didn't hit me in the face causing blindness or whatnot.
          Glad you are healing up
          Why did you have your trousers down though?
          • k.alle
            • Feb 2008
            • 801
            Thx Alex
            Lol, have I not had pants on it would have been catastrophic [emoji14]
            • k.alle
              • Feb 2008
              • 801
              Oh for reference if someone else has these issues, here's a picture of how far I had to move the RS2 cam wheel with the tommis billet sprocket on the crank.
              I'm still looking for tips on best place to get the big radiator.
              • rxl
                • 1913
                wasnt it only half of teeth out? im afraid your out if timing again..
                • k.alle
                  • Feb 2008
                  • 801
                  I cant make i 1/2 tooth out, it is the tommis billet sprocket that does not allow it.
                  It is either 1 tooth out or no tooth out.
                  • rxl
                    • 1913
                    So do You get full boost with the timing out?
                    • k.alle
                      • Feb 2008
                      • 801
                      Yes, no issues in that regard.
                      It was night and day difference when I moved it to this position, to the better!
                      • Rikki Kitto
                        • Feb 2010
                        • 6276
                        Try Vidar Skothiem for the rad
                        • k.alle
                          • Feb 2008
                          • 801
                          Long time with no work on the car but now I have an update.
                          Changed the 2 cam timing gears on the front of the motor to stock ABY ones.
                          Car started to sound like a diesel and since flywheel, bottom & top cam gear / pulleys were at TDC i started to suspect the cams alignment in head.
                          Found this:
                          Corrected the alignment, turning intake cam on the left one sprocket to the right, and voila.
                          Finally I have a pretty smooth idle since the first time I installed the rebuilt engine.
                          Suddenly the car is not a very heavy weight on my shoulders anymore
