coolant system cleaning!
  • Pirvu Eugen
    • Apr 2007
    • 1978
    • Country: Romania
    Hi! I need your advice please!
    My diseasel car... has the oil cooler damaged and alot off oil went into coolant. I bought the oil cooler but i need to clean the cooling system first from oil residues without damaging anything...
    Do you know cleaning solutions, agents...something?
    Thank you!
    Eugen
    Add a dishwasher tablet to the cooling tank
    • Pirvu Eugen
      • Apr 2007
      • 1978
      • Country: Romania
      Really?!!/????
      And? then just flush and repeat untill clean?
      Will not damage aluminum?
      Thank you!
      • LHD_Kid
        • May 2006
        • 3696
        Are you yanking my chain - or is this really a solution?
        • shaun5
          • 1610
          I have done this on tractor engines that have blown there oil coolers (3-4 used in them) ran the engine up on a dyno to get it hot then flush it out.
          Dont know if there is anything that would hurt on a petrol engine???
            The dishwasher tablet dissolves in the water and as it is a surfactant it holds the oil in suspension allowing you to flush it it. Also cleans all kinds of other **** out too. Oxalic acid is really good for breaking down deposits in the cooking system too.
            • Pirvu Eugen
              • Apr 2007
              • 1978
              • Country: Romania
              i will let you know how is it....
              Regards!
              • bikerjim
                • Feb 2008
                • 1028
                I too have used cleaning products to flush a cooling system with very good results!
                • ronaldvossen
                  • Dec 2013
                  • 174
                  • Country: Belgium
                  So uhm... Any brands of dishwasher tablets you can recommend or which we should avoid? What about vinegar? (OK, in won't dissolve oil)
                    • 4754
                    In a recent Which magazine test results on dishwasher tablests, Sainsburys own brand of dishwasher tablet came out best.
                    • Bowie69
                      • Nov 2013
                      • 2675
                      I've done it too
                      Need to do it again, going the Oxalic acid route this time, it is apparently safe enough to leave in for a few days/a number of heat cycles, not sure I would leave a DW tablet in there as long as that -have you seen what they do to aluminium pans?
                      • hunker7
                        • Mar 2014
                        • 3487
                        SO you just pour Oxalic acid in the expansion tank? What sort of amounts?
                        '93 Audi UrS4 Avant
                        '15 Audi A7 quattro 3.0 TDI
                        • Bowie69
                          • Nov 2013
                          • 2675
                          Seen somewhere 3 tablespoons per gallon, so for an I5 I think that's about 6 required.
                          • Pirvu Eugen
                            • Apr 2007
                            • 1978
                            • Country: Romania
                            Originally posted by Bowie69
                            I've done it too
                            This is what wories me too....as radiators and head is aluminum.
                            But i think that for 1 heat cycle will be ok.
                            • hunker7
                              • Mar 2014
                              • 3487
                              How did it go?
                              '93 Audi UrS4 Avant
