I have problem after engine rebuilt. I made aluminium crankshaft pulley and it goes splay on running engine. I thought that it happens of bad aluminium turning and made another one by cnc machine and it goes splay too. Original pulley also go splay. So it is crankshaft problem. So I think that the end of the shaft is bended. I don't think that I could turn the crankshaft clearly after tighteninig pins, if it bended on center or somewhere.
splay amplitude on pulley furthest point from the center is about 2mm
Should I replace crankshaft or could I running this engine with this problem?
