Today was a bit strange day,i was in hurry to a meeting for a new job,and i was afreid that i will be late so i was driving a bit faster,and when i pulled from the traffic lights i had a missfire in second while boosting(didnt hammer it in first,it missfired when i floor it in second on almost full boost),and i toth maybe the batery wasnt tight good(i removed her today so toth thats the problem)then i restarted the car for evry case,couple of minutes later missfire again on boost in 3rd,after that i didnt drive above 2000rpm.
After i come back home i tighten the batery again and went for a test drive,40min+ of driving no problem,almost all time boosting 1-2-3,and when i decided to go home i get missfire in 4th on half the throtle(car was in boost),also for 1 second check engine light come up.
After that i pulled the codes via blink system,and the only fault i get is
2111,G28 sensor(i know its normal to get it when the car is off,so i eliminated it)
Any idea what could be the problem
