Missfire on boost
  • Majorcina
    • Jun 2013
    • 1334
    • Country: Montenegro
    Missfire on boost
    Today was a bit strange day,i was in hurry to a meeting for a new job,and i was afreid that i will be late so i was driving a bit faster,and when i pulled from the traffic lights i had a missfire in second while boosting(didnt hammer it in first,it missfired when i floor it in second on almost full boost),and i toth maybe the batery wasnt tight good(i removed her today so toth thats the problem)then i restarted the car for evry case,couple of minutes later missfire again on boost in 3rd,after that i didnt drive above 2000rpm.
    After i come back home i tighten the batery again and went for a test drive,40min+ of driving no problem,almost all time boosting 1-2-3,and when i decided to go home i get missfire in 4th on half the throtle(car was in boost),also for 1 second check engine light come up.
    After that i pulled the codes via blink system,and the only fault i get is
    2111,G28 sensor(i know its normal to get it when the car is off,so i eliminated it)
    Any idea what could be the problem
    One missing and hesitation diagnostic
    Coils, Plugs, POSs, MAF. Take your pick.
    Start by reading this:
    • Costash
      • 878
      • Home: Romania Current: United Kingdom
      Old coil pack failure ...
      • Majorcina
        • Jun 2013
        • 1334
        I am on phone so i will read it detailed when i come home.
        But,got upgradet tfsi coils,new ngk spark plugs with less then 1500km on them,also POS have been deleted when harnes for coils has been made.
        • Costash
          • 878
          Possible a bad connection ignition related.
          • hunker7
            • Mar 2014
            • 3487
            Still, could be coils or spark plugs. Oh wait, you say they are NGK, check the gaps, geneandbolly on here had the same issue and he re-gapped them and it was all running fine.
            if i remember rightly the ngk plugs are gapped at 0.75mm out of the box. they should be 0.6mm for the aan engine.
            i can't believe that 0.15mm can make such a difference (said the nun to the bishop).
            '93 Audi UrS4 Avant
            '15 Audi A7 quattro 3.0 TDI
            • Majorcina
              • Jun 2013
              • 1334
              Will check it out Janis
