Exhaust Manifold Removal??
  • S2Roo
    • 191
    Hi peeps,
    I'm trying to remove my cylinder head, and I have remove everything required, except the exhaust manifold. I have remove all the nuts off the studs, and I have removed all but 5 of the studs, and I am finding it very difficult to get to these. I cannot move the head side ways an up because of the dowels in teh head. Has anyone got a BTDT of how to get round this?? Thanks in advance.
    Roo
  • martinjs
    • 3205
    I found it easier to remove it with both manifolds and the turbo still attatched, a bit of manovering is required to clear the dowels in the block and studs on the back of the turbo which are in the downpipe.
    Its bloomin' heavy mind!
    martin
    • S2Roo
      • 191
      How do you get it off dowels in the block, and then forward off the studs in the turbo???
      • S2Roo
        • 191
        Will a stud extractor fit on the studs on the lower side of the exhaust manifold???
        • martinjs
          • 3205
          Have you undone the downpipe where it is connected to the bottom of the gearbox?
          That should give a bit more play in the downpipe. You should only need to lift it a few mm to clear the dowels in the head then pull it all forward to clear the turbo from the downpipe.
          martin
