Automark
Mark for me every time. Straightest man you'll meet. The negatives that you will read is that he doesn't map the boost map and prefers manual boost control. If you ask him he will map the N75 he just doesn't think them reliable enough for his customers.
One of the nicest guys I've met.
Darren.Comment
latest pic off mark tonight GULPAttached FilesABY Cricket Green Pearl Coupe, blk leather
THE ONLY TROUBLE WITH DOING NOTHING IS KNOWING WHEN YOUR FINISHED!!!Comment
AHH BetterAttached FilesABY Cricket Green Pearl Coupe, blk leather
All belts and chain, water pump thermostat, Rs2 exhaust manifold ceramic coated ,7a exhaust cam, alloy billet timing pulley , new N75 your Chris's rear brake upgrade,repainted , front callipers serviced and repainted all alloy engine parts media blasted new injectors and seats, R8 coil packs with custom made loom. new fuel lines where needed, custom remap of course,
Oh yes and a brand new Rs2 hybrid turbo!
Thought it deserved a treat for its 21st [emoji512] [emoji512] [emoji512]Last edited by vonbeck; 13 July 2015, 23:51.ABY Cricket Green Pearl Coupe, blk leather
My old S2 came with an Automark map, the car wouldn't run correctly.
Took the car for diagnostic and the chips were not written correctly and failed checksum which was one of the issues as well as being stock RS2 ignition when it supposed to have been custom mapped.
Had to have the chipset removed and replaced with the correct custom one and one that controlled the N75.
Only met the guy once, for a tuner he's one of the nicer guys in person but being a nice person doesn't mean it's good work, infact some less than personable people do better work.
The bullshine I see that the N75 isn't up to the job, the only advantage is the silly reduced boost on part throttle of the stock ecu and only full boost with WOT. I'm sure people have got around that by now. I have no idea my S2 knowledge has dwindled.
Pay your money takes your choice.
S2 map runs spring until nearly full throttle but the RS2 chips I've tried run much more part throttle boost. The TS Tuning chips that are common generic upgrades now run a very aggressive part throttle map and the prj chips that I now have are quite linear.
Jamo, it sounds like your secondhand experience wasn't ideal but am I right in remembering that there were a few things with that car that weren't as described when you bought it? Are there other instances of issues that you can identify?
N75 can be mapped around, as even the stock 0.4 Bar spring is boost assisted, so without that assistance, you can get over 2 bar (as any RS2 proves). The N75/WG system is fail UNsafe, as boost opens the WG, not closes it
As I see the risk of live mapping as being too great in today's speed obsessed world, unless prj could map on a RR, I'd have to consider Mark or Danny (VEMS) as an alternative. MRC do still do S2s (dobbin recently) but I've heard prices that approach those of custom ECUs. Maxx ECU is interesting but I'm not sure of UK tuners for it and I'm sure there are more (sure Terryb's had most - tatech?). The more off-piste you go, the further afield you have to look - I am reminded of Yogi's experience with his 90q... Nowt wrong wih custom, as long as there are a few trusted peeps you can use.Last edited by Rusty; 14 July 2015, 09:32.Cheers'en, AndyC
1994 ABY Coupe - Projekt AlpinweissComment
Happy Birthday car, hope you enjoy all the love being lavished on youAll belts and chain, water pump thermostat, Rs2 exhaust manifold ceramic coated ,7a exhaust cam, alloy billet timing pulley , new N75 your Chris's rear brake upgrade,repainted , front callipers serviced and repainted all alloy engine parts media blasted new injectors and seats, R8 coil packs with custom made loom. new fuel lines where needed, custom remap of course,
Bet ya can't wait to get ya hands on it
There a few mechanical issues but the car was taken to MRC who sorted them all initially after i bought it. for a year it was fine until the headgasket went and then I went stroker............ crazy idea never do that againS2 map runs spring until nearly full throttle but the RS2 chips I've tried run much more part throttle boost. The TS Tuning chips that are common generic upgrades now run a very aggressive part throttle map and the prj chips that I now have are quite linear.
I've met a few people who have said they can remap the Motronic, the most interesting chap being in Blackpool.
I spoke to Motorsports development in Blackpool quite a lot about live mapping my URS4.
They went in to great detail (far beyond what I knew), and I have no doubt the could map it, however the quality is just a complete unknown (same for any tuner not familiar with the cars).
Due to that I changed my Albert K26 to an RS2 and a PRJ map.
Wether it was the correct choice to compromise on a turbo for a known suitable map who knows.Comment
1976 RD250E / 350LC cafe racerComment
1994 16v Coupe - Sold on and sadly missed
1994 S2 Avant - Warmed up a bit
1995 A6 Avant - Dag Dag DelightComment
