I have one of alberts K26 turbos i'm planning on fitting and heading to automark to get it tuned. Is it safe/ or is there a safe way for me to fit the turbo before i drive down to automark with out damaging the engine?
K26 turbo
Yeah, keep the stock injectors fitted and disconnect the N75 and you'll be fine. If you fit the larger injectors required for the K26 you'll most likely be running pig rich on stock software.1990 B3 2.0 80 quattro.
1992 C4 2.8 Avant quattro
1994 MTM RS2.
1998 B5 TDI quattro Sport.
2000 B5 TQS.Comment
