RS2 with a boost leak . . .
    MFTS faults will only cause the ECU to cut boost to spring pressure, I. E. no active boost control, it won't cause limited or partial boost. As I said before no point guessing, pull the fault codes.
      This is the normal scenario, the MFTS can
      A/ fail and reduce boost
      B/ fail and show wrong temp
      C/ fail and show overheat sign in dash along with beep noise
      D/ a combination of any or all of the above..
      • veneto rs2
        • Jun 2006
        • 1022
        • Country: Veneto
        #33
        I second that.
        And switch off the A/C accordingly
        http://www.audisportclub.com/
        • Juvkam78
          • Jul 2015
          • 46
          • Country: Norway
          #34
          Man I love this forum, my ABY cuted bost on friday to 0,7 bar and i was almost giving up until i found this thread, unplugged MTFS and the boost was back
          Nur quattro
          1994 S2 Coupe
          • Golfboy666GTI
            • Sep 2008
            • 571
            • Country: New Zealand
            #35
            I should have updated this. I replaced the MFTS sensor but I am only getting 8-10 PSI.
            Could it be a broken wire from the plug?
            Also, the plug is looking pretty brittle, can this be purchased separately?
            1980 VW Golf GTI Track Car
            1995 Audi RS2
              F76 Multifunction Temperature Switch R&R Info (with Cross Links to G62 Coolant Temp S
              Originally posted by Golfboy666GTI
              I should have updated this. I replaced the MFTS sensor but I am only getting 8-10 PSI. Could it be a broken wire from the plug?
              F76 MFTS wiring info is contained in this post:
              F76 Multifunction Temperature Switch R&R Info (with Cross Links to G62 Coolant Temp Sensor):
              Which I accessed by clicking on the "MFTS" label in this diagram:
              http://members.shaw.ca/ajmills/UrS%2...ice%20Map.html TRY IT!!
              • le mans
                • Nov 2013
                • 165
                #37
                Great to see you got your interractive device map up and running again Dave. Good man!
                Nik, in your other thread you mentioned all was OK after trimming vacuum line and installing new DV?
