Anyone have vacumn diagrams for aby motor?
  • Josh-stateside
    • 741
    Or some really good pictures of the back side of the motor?
    I will take some pics possibly tomorrow and show everything that I am questioning.
    Josh
  • Glen Chamberlain
    • 375
    I may be just thinking out loud but is there not a diagram on the bonnet nr the N/S mirror? I may be thinking of a different Audi but i know one of mine
    had one there!
    Money is everything! Second to Power of course!!! But money breeds power??
      Didn't I post a JPG on this last week or so ?
      I'll dig it out of a different machine and post it again tomorrow. I did one for the 3B and one for the ABY.
      Cheers,
      Paul
      • Josh-stateside
        • 741
        In reply to Glen.
        I am working on a conversion from 7a-aby.
        I have very little info.
        I think I have it all figured out thought to be honest.
        But if you don't mind paul it would be appreciated, I never saw the other posts, but I will look for it.
        The lines I have in questions.
        There is one for the AC, but since I elimated it, i am going to just plug it.
        The vavle for AC on a 7a and 3b motor is inside the engine bay, and it's in the dash on the aby models. So I was confused on that thought.
        There is another line that runs to the Diff locks (haven't confirmed but it's a white plastic line I believe)
        There is the boost line. (Green plastic line, I have this figured out, simple enough)
        Once I realized the AC parts were different it got alot simpler.
        Josh
          Here's the vacuum tree diagram for ABY -
          CHeers,
          Paul
          • Josh-stateside
            • 741
            Sweetness!
            paul
            You Rock
            • BRY
              • 3755
              So, is it the same connections for a 3B?
              • jon_91_s2
                • May 2004
                • 253
                • Home: England
                3B is not the same. From what I can work out from the diagram it is similar, but one immediate difference is the 3B has three hoses in that area. One goes to the bottom of the DV.
                Jon
                91 3b S2
                Now Sold
                • mcandmar
                  • Apr 2004
                  • 5118
                  Sweet In the process of planning my 7A -> ABY conversion, could'nt for the life of me figure out what that white plastic bit was for, its a moisture trap then
                  Any diagrams for the carbon canister and check valves? 7A has two valves where as the ABY seems to have one, i also need to know where it is plumbed in
                  91CQ20v - Gone to a new home
                  93UR-S4 - The Magic Carpet
                  94S2Bus - The Emerald Express
                    The 3B vacuum is very similar of course - but not identical to the ABY. Most notable difference is that the control pipe for the TBV comes from rear of the IM - with a hilariously long run of pipe over the EM before it finally gets down to the TBV.
                    Will post the 3B diagram (two years old now) later today...
                    As for carbon canisters - I'll cover that separately. Could probably justify an update on S2central.net for this info - then it will be SO much easier to find again.
                    From memory of the EVAP system, the carbon canister has two connections - one accepting fumes IN from the tank, and another taking them OUT via the N80 solenoid which allows them into the IM on vacuum.
                    Duty cycle of N80 is controlled by ECU......
                    Paul
                    • GTQ
                      • Jul 2008
                      • 5
                      I'm doing similar 7A to ABY conversion and have yet to see a proper diagram of the vacuum routing as it pertains to the Evaporative Purge Valve and related Crankcase Ventilation. I can mod for catch can later once I know what the stock system looks like.
                      A picture of this would be great - the theoretical diagrams just don't show how the factory hookups are made. I'm trying to make this as factory as possible, then deviate if need be.
                      Ben
