Take the 1200cc EV14. Good place to buy finjector or ebay/fiveo. I would have a set of 1200cc on the shelf but I'm not sure if I wan't to sell them.
TJ: i have Deka 850cc on my car. they're nicely on idle but just curious if anyone has the appropriate injectors deadtime on this injectors?
i also run 850cc on 5bar FPR.
Ooh yes, you'r right. I had adapters on mine. Didn't see that you link EV14's had different connectors.
Order contents:
EV14, Bosch, 957 CC ,12 ohm, C30°, Jet -liitin, pitkä kärki, O-O 34 mm (0280158040)
Suuttimen jatkoholkkisarja14 mm bensakiskolle, sis. tiiviste ja kiinnitysklippi (TOP14-CLIP)
Suuttimen alaosan MUSTA jatkoholkki pitkäkärkisille suuttimille, sis. 14 mm tiivisteen. Peittää suutinkärjen ja jatkaa O-rengasvälin seuraavaan pituusluokkaan. (BOTTOM-SET-2)
I have 4 bar fuel pressure and mine idles ok with petrol. I have also used these with ethanol over the past 5 years on drag strips. No problems with them.
I had Siemens 850cc but after using them for about 6 months, i got idling problems like many others. So i would not suggest using Siemens Deks injectors.
