G28 sensor issues.
That is a strange one for sure, are there the correct number of teeth on the flywheel?
Not likely to be this in this case since the starter is the other side of the engine, but we recently had a similar issue with a TD5 Defender, which turned out to be a failing starter (which worked perfectly in as far as it turned the engine over at a normal speed) that was throwing out weird electro-magnetic signals effecting the engine speed sensor. I wouldn't have believed it if I didn't see the result from a new starter! :OComment
You do get the "no signal" code while the engine is not running, but the other one I'd not expect to see unless there is an issue...Comment
It is possible then that the number of teeth is different, a tooth is missing, or the trigger has fallen off, although the trigger having fallen off shouldn't affect the speed sensor (directly)Comment
Crank Position (G4) and Engine Speed Sensor (G28) Info - Function , Location and PNs
You might be confusing the G4 crank position sensor pin ("trigger") with what the G28 is looking for. The G28 just counts teeth.
REF: Crank Position (G4) and Engine Speed Sensor (G28) Info - Function , Location and PNs
Are the G4 and G28 plugs swapped?Comment
Thanks for the pics. The engine is in our buggy so the wring is a little different. See thread - http://www.s2forum.com/forum/showthr...t=53745&page=2Comment
I went through most of the thread. I get the buggy thing now. Did I miss a photo of the AAN connector rack (which you might have used??)Thanks for the pics. The engine is in our buggy so the wring is a little different. See thread - http://www.s2forum.com/forum /showth...t=53745&page=2
Just showing that the application is a little different from norm and the wiring and connectors aren't in the OEM positions. There's no wiring specific picture to see, that other thread is a couple of years old.
The ecu needs G28 Engine Speed, G40 Cam Position Sensor and the G4 Crank Position sensor to start. Perhaps it's an earth issue as when strange things happen, that's often the culprit. We'll check the ECU earth wire and engine earth strap.
BTW - This engine has not been started since was rebuilt, so there is another unknown to factor in.Comment
