Oh how I know that the AAN (And 3B, ABY and ADU) ECUs need good signals from all three of the G40, G4 and G28 group to start. I have explaining this for years:
G40 info: http://forums.quattroworld.com/s4s6/msgs/22580.phtml
G4/G28 info: http://forums.quattroworld.com/s4s6/msgs/20986.phtml (Check for a missing G4 reference pin on the flywheel: http://forums.quattroworld.com/s4s6/msgs/51259.phtml
Grounds are absolutely essential to the ECU since always takes things to ground, rather than actually providing them directly with power. Case in point is the J17 fuel pump relay. The AAN ECU grounds were on the intake manifold in the C4 chassis.
J17 FP relay info: http://forums.quattroworld.com/s4s6/msgs/22583.phtml
