My 3B is smoking constantly, a white-ish grey coloured smoke, with puffs of after a hard rev and also under boost, fumes from exhaust is suffocating when started indoors, engine has used so much oil when dipped it was barely showing on the dipstick, car has a drip from the rear main seal but nothing to the extent that it would near empty engine.
So the plugs came out for a look, some lightly fould some not, cant remember which ones of the top of my head.
Then compression tester came out,
All tests done with all plugs out and throttle wide open.
COLD DRY COLD WET
1. 10.9 BAR 1. 12.6
2. 10.3 2. 12.4
3. 10.1 3. 12.4
4. 9.9 4. 12.4
5. 10.3 5. 13.1
HOT DRY HOT WET
1. 10.9 1. 12.5
2. 10.9 2. 13.4
3. 11.3 3. 13.1
4. 11.2 4. 13.5
5. 11.1 5. 13.6
Any help/advice is welcome.
steve
COLD DRY COLD WET
1. 10.9 BAR 1. 12.6
2. 10.3 2. 12.4
3. 10.1 3. 12.4
4. 9.9 4. 12.4
5. 10.3 5. 13.1
HOT DRY HOT WET
1. 10.9 1. 12.5
2. 10.9 2. 13.4
3. 11.3 3. 13.1
4. 11.2 4. 13.5
5. 11.1 5. 13.6
steve
