In the process of gathering parts for a timing belt change on my avant (no easy task
Ordered water pump number 054 121 004AV as per s2central guide (26 teeth). Surprisingly i was told £79 +vat not too bad i thought.
Collected parts today and invoice says 054 121 004AX which i've also read is correct for ABY on the forum. This number matches the box from audi so i thoughti've cracked this, i can get car booked in to get the job done.
Always double, no, triple check! Number stamped on pump is 054 121 019A
It has 29 teeth which is supposedly RS2 spec or am i getting myself totally confused here?
Have i just bagged myself a RS2 water pump by mistake
The irony is i believe my car runs RS2 water pump/belt setup, but i was planning on changing it back to ABY setup for simplicity!
)Ordered water pump number 054 121 004AV as per s2central guide (26 teeth). Surprisingly i was told £79 +vat not too bad i thought.
Have you seen this part number before Dave? Is it a replacement for 054 121 004AX
