I have converted from 3B to ABY washer bottle and have therefore lost the mounting point by the headlight. It used to screw into the headlight washer bottle. Is there a bracket or something fitted to the ABY which this corner fixes to?
Thanks
Been checking photos online. Can't find one showing what I need
Chris there is a piece of plastic trim in front of the PAS tank on the ABY, the fluid supply to the pump passes through it. The rad shroud bolts to that.
Gotta make a little bracket methinks, can't use the existing ABY solution
