What holds ABY radiator shroud in place?
  • LHD_Kid
    • May 2006
    • 3695
    I have converted from 3B to ABY washer bottle and have therefore lost the mounting point by the headlight. It used to screw into the headlight washer bottle. Is there a bracket or something fitted to the ABY which this corner fixes to?
  • LHD_Kid
    • May 2006
    • 3695
    Nobody got an ABY with a shroud...?
    Been checking photos online. Can't find one showing what I need
    • quattro-nick
      • Sep 2012
      • 1746
      • Country: Belgium
      can you see it on the picture chris?
      TWINCHARGED power,zero lag
      AEM W/M injection
      • sjw185
        • 1175
        Is it the plastic bracket attached to the wing?
        ABY has 3 screws and the two plastic clips on slam panel
          Chris there is a piece of plastic trim in front of the PAS tank on the ABY, the fluid supply to the pump passes through it. The rad shroud bolts to that.
          • LHD_Kid
            • May 2006
            • 3695
            Thanks chaps... just what I needed to know.
            Gotta make a little bracket methinks, can't use the existing ABY solution
