Core plug!
    Core plug!
    Oh FFS, still it's probably a good thing this happened this evening while I was out for a little fun and only a half mile away, rather than Saturday on the circuit or the M4 at 80mph..
    Item 7: 28 mm head plugs (one front, one rear): N 0119082
    Item 5: 9.5 mm plug, rear of head: 034103379
      Cheers Dave, item 7 I reckon
      I bought one of these.
      http://www.ebay.co.uk/ulk/itm/321422964093
        No, one of these !
        http://www.ebay.co.uk/ulk/itm/201258491810
        • Christophski
          • 3632
          Is that a head off or engine out job to get to?
            I think I can do it in situ
              Can you see the thin stream of water? It was absolutely screaming out
              • mike74
                • Apr 2014
                • 615
                that looks like a seriously unpleasant job to fix!
                you're definitely lucky to be so close to home when it popped, otherwise it would've been a flatbed ride home
                  My guess is you run a big metal screw into the center of the defective plug and then use the screw to help pry out the plug.
                    I was having fun getting one of these out of a head on the bench the other day. Good news is there is no step in the hole behind it so you can use a punch to knock it sideways then pop it out
                      ON THE BENCH.
                        Make sure to have a new water pipe flange in either plastic or metal, the one that is lower down the back of the engine underneath your core plug, as you'll probably put pressure on the exiting one, as it is no doubt old and has lots of heat cycles, and it will then fail a while later when you don't want it to, so as you're "in there" definitely do it.
                          Originally posted by UrS4boy
                          ON THE BENCH.
                          Noted
                            I was thinking that, it's a 3B so probably the metal original..
                            • mcandmar
                              • Apr 2004
                              • 5118
                              On the list of nightmare jobs to do, that is right up there with the best of them. Getting the old plug out is easy enough, pressing the new one is going to be a real challenge. If you get stuck one of these might get you going..
                              http://www.ebay.co.uk/itm/7-8-Rubber...UT4g0X78zmJMNg
                              91CQ20v - Gone to a new home
                              93UR-S4 - The Magic Carpet
                              94S2Bus - The Emerald Express
