5 pot Volvo 850
  • Trist28
    • Dec 2008
    • 725
    5 pot Volvo 850
    Not S2 but........
    I have a 93 Volvo 850 GLT which has a 2.5 5 pot petrol motor. Non turbo. I paid the princely sum of £100 for it and have had great fun having such a budget tank. I have used it for 2 years without issue.
    Ive had starting issues on 2 occasions over the last few months but put that down to flooding as it stunk of fuel - and started easily when left for a hour.
    The new problem is a little more tiresome though....
    Was out and about in it and drove home, parked up and she refuses to start - at all.
    I have the following
    Fuel pressure at inlet manifold, cranking fine, spark at coil and to plugs
    Timing belt fine
    Pulled injector rail - injectors not firing. Put drop of fuel in cyls and she fired fine.
    Checked all fuses and relays for signs or issues - none found
    Would you guys agree it must be cam or crank sensor? If so does anyone know the test methods -I have a multimeter. Problem is to change them both will cost more than I paid for it If it fixes it fine but if it doesn't it spoils my budget motoring!
    I have no clue how the Vulva 5 pot ignition/fueling systems work but if it was an Audi, the first thing I would ask would be: "Have you pulled the DTC codes?"
    The DTC codes would flag a wonky cam or crank sensor and lead you to a solution.
    Obviously this problem existed and persisted before you got the car and the issue was reflected in the selling price (the owner wanted well away from the car). His loss will be your gain if you can figure this out.
    Pull the codes.
    • K Simmonds
      • Dec 2007
      • 7627
      I'm not sure Tristan can pull the code on it, does it have a diagnostics port mate or have you pulled the codes and not gotten any help?
      It's a new problem as he's done a lot of trouble free miles since acquiring it a couple of years ago, if you saw the car you'd understand why it cost so little, the bodywork is shall we say tired?
      Great car fun, practical car though so I can understand you wanting to sort it.
      Maybe some of the Scandinavian members may have some ideas and knowledge of the systems on the car.
      1990 B3 2.0 80 quattro.
      1992 C4 2.8 Avant quattro
      1994 MTM RS2.
      1998 B5 TDI quattro Sport.
      2000 B5 TQS.
      • Ryss
        • Nov 2009
        • 233
        • Country: South Africa
        efi?
        Regards
        Ryss
        www.autostart.co.za
        • Trist28
          • Dec 2008
          • 725
          To confirm - Its a 2.4 not 2.5 and has Bosch engine management.
          Has 2 ecu, each the same size as a motronic ABY ECU.
          The previous poster..... Yes it is electronic fuel injection
          • elaw
            • Jun 2012
            • 62
            I don't know about that engine specifically but a generic suggestion: have you checked to make sure the timing belt hasn't jumped a tooth or three? With some engine-management systems that will throw off the timing between the crank and cam sensors enough to piss off the ECU and make the engine not start.
            Another thought: you say it has two ECUs... most likely that means one's for spark and the other for fuel. Since it has spark and no fuel, that means the fuel ECU could be at fault. Is there any chance you can get your hands on a known-good one to install as a test?
            Be alert! America needs more lerts.
            Eric Law
            '90 80Q with AAN and Megasquirt
            '97 Saab 9000 Aero: mostly stock but ECU tweaks to add fastness
            '86 4KTQ: R.I.P.
            • John.
              • 2615
              Do you have voltage to the injectors or is it a switching issue?
              • mdz
                • Jun 2012
                • 775
                • Country: Latvia
                850 has a diagnostic unit in the front of engine bay where you plug a wire into socket and watch LED flashing to get fault codes. There's pdf files with process description, fault code list and troubleshooting floating on the internet. I have one about 850 abs system as I once had to fix it, but I can search for one about engine management tomorrow.
                • K Simmonds
                  • Dec 2007
                  • 7627
                  He's not getting any voltage to the injectors at all, fault codes would be really useful if you could find out how to pull them it would save a lot of guess work.
                  1994 MTM RS2.
                  2000 B5 TQS.
                  • John.
                    • 2615
                    Main relay or wiring fault then surely, ECU will likely only switch the injectors on that vintage?
                    • Jamin
                      • Feb 2011
                      • 83
                      • Home: England
                      Some info here: http://www.volvotips.com/index.php/8...repair-manual/
                      1992 80 quattro 1.8T
                      • K Simmonds
                        • Dec 2007
                        • 7627
                        That was pretty much my first though when Tristan ran the problem by me.
                        1994 MTM RS2.
                        2000 B5 TQS.
                        • mdz
                          • Jun 2012
                          • 775
                          • Country: Latvia
                            850 Diagnostic Codes
                            Originally posted by Jamin
                            Here is the key part of that list:
                            Volvo 850 service & repair manual TESTS W/CODES 1995 Volvo 850 1995 ENGINE PERFORMANCE Volvo – Self-Diagnostics INTRODUCTION If no faults were found while performing procedures in the F – BASIC TESTING article, proceed with self-diagnostics. If no fault codes are present, proceed to the H – TESTS W/O CODES article for diagnosis by symptom […]
                            Here is more:
                            http://www.matthewsvolvosite.com/read-codes-volvo-850
                            Here is Figure 1 from the first link (in case it goes missing):
                            • Trist28
                              • Dec 2008
                              • 725
                              Thanks for all the useful replies guys - appreciated.
                              I will get onto the blink codes and see what that tells me.
                              I will report back
