Front Pulley Friction Shim
  • goodall
    • Jul 2008
    • 810
    I came across this, http://rosten-performance.com/produc...ankshaft-shim/, its designed to prevent the key on the front pulley shearing. Could be a good way to prevent the fatigue cracking of an OEM pulley
    Of course part mentioned is for a 2.5tdi and that how I found it in regard to my ti project but the design and theory is the same
  • quattrostyle
    • Oct 2006
    • 6229
    So that's the diamond washer as fitted to later 20VT engines?
    • gnutz2
      • Aug 2006
      • 928
      Interesting, although a correctly torqued pully won't come loose. Just like the website mentioins, cracked keyways are usually an installation fault.
      The ONLY S2 Golf!
      http://www.s2forum.com/forum/showthread.php?t=19402
      10.42@138mph
      https://m.youtube.com/watch?v=0wnkkOfFpXg
      • brianb
        • Aug 2008
        • 248
        No.
        • quattrostyle
          • Oct 2006
          • 6229
          Same idea I guess?
          • K Simmonds
            • Dec 2007
            • 7627
            Same idea I guess?
            Maybe...though the 20VT washer is approx 2mm thick and also acts as a spacer vital to correct pulley alignment.
            I have one of the diesel items in a draw of odds and sods, can't remember for the life of me where it came from.
            1990 B3 2.0 80 quattro.
            1992 C4 2.8 Avant quattro
            1994 MTM RS2.
            1998 B5 TDI quattro Sport.
            2000 B5 TQS.
            • Rikki Kitto
              • Feb 2010
              • 6276
              They're £34
              • AndyP
                • 6049
                The shim for the TDi is just that, a shim, I think it's 0,25mm thick. I think they are about £12 from Audi, but they won't be any good on a petrol as they will throw out the pulley alignment.
                • mac2226
                  • Jun 2008
                  • 1289
                  So do 3b engines have this shim? Only asking because my Aby had 1
                  • elaw
                    • Jun 2012
                    • 62
                    I know on the AAN, the early ones did not have the washer, and the later ones did... along with a different damper pulley. The later items superseded the earlier, so if you have an early one and want to replace the damper, you have to buy the washer also.
                    I imagine it might have been the same with the ABY, but since the 3B was earlier I would not think any of those would have the washer.
                    Re the washer mentioned in the first post, the website says it's only 0.1mm thick which is less than 0.004". That probably would not affect pulley alignment enough to matter.
                    Be alert! America needs more lerts.
                    Eric Law
                    '90 80Q with AAN and Megasquirt
                    '97 Saab 9000 Aero: mostly stock but ECU tweaks to add fastness
                    '86 4KTQ: R.I.P.
                    • goodall
                      • Jul 2008
                      • 810
                      Yes I imagined this would be a upgrade part to stock set up as its only 0.1mm/4 Thou thick and pulley alignment will be ok. I currently use a 7A pulley on my 2.5tdi and am likely to use this as an upgrade, or a stronger bolt torqued higher...
