Earlier this year I melted a piston in my engine, and I really wonder how it happened, as the engine worked fine until the breakdown. I was in 6th gear, doing about 60km/h when I stamped the loud pedal. The boost came and the engine went kaboom.
I took the piston to a local engine builder with 20 years experience when it comes to these engines, but he could not offer an explanation, he had not seen this type of failure before. The only theory he had was that the injector somehow got stuck in open position and dumped gas on the piston.
There's no indication of the engine running lean, and all the other cylinders were ok.
Here's a couple of pictures:
. I've never seen anything quite like that before!
Hope you can find out what cause it!
