brake/steering fluid fault light
  • audi660
    • Jan 2005
    • 162
    • Country: South Africa
    I've just finished rebuilding my motor but the brake/steering fluid check light stays on. Its the red circle with exclamation mark on the dash. All the fluid levels are fine and plugs are attached.
    I didn't have this problem before the rebuild
    [SIGPIC]1997 Ur-S6 SMS Revo S
  • mike74
    • Apr 2014
    • 615
    Maybe the float/level sensor on the reservoir cap has stuck, BTDT. There should be a tiny plastic pin sticking out the top of the cap that's connected to the float. If this isn't visible it might be stuck in the 'down' position ie no fluid. Or the sensor itself has failed...
    • audi660
      • Jan 2005
      • 162
      That pin is fine. Where is the sensor located?
      • veneto rs2
        • Jun 2006
        • 1022
        • Country: Veneto
        Also level sensor on brake fluid reservoir on top of master cylinder can be the culprit.
        The part is still available at Audi dealer also dead easy to slide it out and change
        http://www.audisportclub.com/
        http://www.s2forum.com/forum/vbgoogl...227295&zoom=16
        • piotr
          • Jul 2012
          • 1470
          Mine was doing that.I disconnect both sensors(PAS and brake fluid)and the light went out.Connected back PAS ,light still out,connected back brake fluid level sensor light came back on.I replaced the sensor-happy days
            Don't know why I am doing this. You should be using Ekaterina and learning where parts are yourself. But I am
            MC level sensor = http://audi.7zap.com/en/rdw/audi+a6+.../611-611010/#7
            PS/PB pump fluid reservoir info: http://audi.7zap.com/en/rdw/audi+a6+.../422-422045/#2
            Ekaterina use Tutorial from a few days ago: http://www.s2forum.com/forum/showthr...ight=Ekaterina
            • audi660
              • Jan 2005
              • 162
              Unplugged both sensors and the warning light still stays on. Is there another electrical plug that these sensors use or maybe a fuse somewhere?
                This can be triggered by 3 sensors:
                PAS fluid level - (float switch in reservoir cap)
                Brake Fluid level - (level sensor on reservoir)
                Hydraulic pressure (pressure sensor on bottom of servo)
                They all work by pulling to ground. Therefore if you disconnect all the sensors, the light should go out and stay out.
                Then plug back the sensors one by one until you find the culprit.
                HTH
                • A1QSHIP
                  • Aug 2004
                  • 975
                  HTH
                  Had the pressure switch fail intermittently on my 7a Coupe.
                  HTH, Chris
                  "Nulla tenaci invia est via"
                  • audi660
                    • Jan 2005
                    • 162
                    Where is the pressure switch located?
                      • audi660
                        • Jan 2005
                        • 162
                        Thanks, only saw that after I replied.
                        I've disconnected all 3 and the light stays on
                          Then you have a short to ground on that circuit.
