Car won't start - 2nd cylinder full of fuel
  • hunker7
    • Mar 2014
    • 3487
    Wouldn't the fuel push passed all injectors in that case?
    It should run on 4 cylinders, but maybe because 1 is leaking it can't get the pressure up?
    '93 Audi UrS4 Avant
    '15 Audi A7 quattro 3.0 TDI
    • Pirvu Eugen
      • Apr 2007
      • 1978
      • Country: Romania
      Leaking fpr through the vacuum hose. Ruptured Diaphragm?.
      • hunker7
        • Mar 2014
        • 3487
        It's possible. I have a spare FPR and dad is sending me injectors. So I will start with replacing injector and if it doesn't run, FPR is next on my list. Because fuel is arriving, and spark is there too.
        '93 Audi UrS4 Avant
          Easy to find out, pull the small vac pipe off the FPR, if it has fuel in it then there's your problem.
          • hunker7
            • Mar 2014
            • 3487
            #20
            Just pulled it off and it looks dry, I sucked on it too and didn't get any fuel so that seems good.
            '93 Audi UrS4 Avant
              Maybe the injector harness is shorting to ground. Check all the harness wiring for damage
              • hunker7
                • Mar 2014
                • 3487
                #22
                I can check it, but harness looked in very good condition, and with no rips or tears when I did the engine work.
                '93 Audi UrS4 Avant
                  Any news?
                  • hunker7
                    • Mar 2014
                    • 3487
                    #24
                    Waiting on postman Pat for replacement injector. Took all the spark plugs out so hopefully they'll be dry by now, and same goes for cylinders
                    '93 Audi UrS4 Avant
                      I reckon if one injector is stuck open it will drown the plug, then when inlets open fuel will come back out into inlet and wet the others
                      • hunker7
                        • Mar 2014
                        • 3487
                        #26
                        That's a good point, because the amount of fuel spatting out of cylinder when cranking the engine was loads. And there is fuel in sump too now.
                        '93 Audi UrS4 Avant
                        • Thuppu
                          • 4115
                          Fuel in sump evaporates fast when the oil temp rises, if you get it started up. Of course if the bottom end is full of fuel then you need to drain it out and change oils.
                          • hunker7
                            • Mar 2014
                            • 3487
                            #28
                            So there is no need for oil change?
                            '93 Audi UrS4 Avant
                            • Thuppu
                              • 4115
                              Not if there isn't a huge amount of fuel there.
                              • hunker7
                                • Mar 2014
                                • 3487
                                #30
                                Doesn't seem to be a lot. I'll drive a bit and check it, if needed I'll change the oil.
                                '93 Audi UrS4 Avant
