Damage top of the Pistons?Investigation help!
  • popdemonic
    • Dec 2007
    • 1304
    • Country: Thailand
    I pulled the AAN head off today.i planned to swap another rebuild head in.
    unfortunately,i found there's a lot pitches on the top of #1 2 3 pistons as you
    seen on the photos.the #3 is the worst volunteer.Can anyone help me investigate
    if the top of the pistons damage due to some metal fell off or the Detonation did this.
    my car is running on VEMS standalone and E85 biofuel.I occasionally heard some kinda
    knock when WOT.i had been running 034 software back in the day and the knock noise
    seems much more worsen but never got any pistons damaged just like this one.I checked the spark plugs,all is great shape.i still couldn't imagine if something could
    fell off into the chamber.
    piston#1
    piston#2
    piston#3
    piston#4
    piston#5
    Head..
    turbine wheel looks fine.
    compressor wheel looks fine
    ignition timing table.max boost is 270-280kpa.
    one of a few I5 from Asia.
  • Thuppu
    • 4115
    You really shouldn't hear any knock with e85. Looks like quite a lot of timing there.
    • popdemonic
      • Dec 2007
      • 1304
      • Country: Thailand
      Thomas,
      I will be pulling my timing back 10deg whole table.i start to think its
      caused by detonation.lesson learn.the good thing is i found this before
      Some worse case scenario happened on cylinder walls
      • SteveH
        • 4460
        It's hard to tell from the pics but it looks like particles of metal stuck into the pistons and not missing material. Not sure it's detonation...
        91 Modded 3B
        14 A6 Avant Black Edition
        • rst
          • May 2006
          • 102
          What fuel injectors are you using? There is quite a lot of tar on the pistons. I have seen this kind of tar before when fuel injectors spray angle was to narrow. Is there any damage on cylinder walls? It looks more like something went through the engine rather than detonation damage.
          Audi UrS4 609hp/846Nm @ wheels
          10.911@210, 1km 268km/h, 1mile 295km/h
          FATS 2,30 sec
          • Thuppu
            • 4115
            Only squish area smashed... If there have been a object inside there should be some marks also elswere.
            • pasbogdan
              • Sep 2009
              • 1160
              • Country: Romania
              Originally posted by popdemonic
              Thomas,
              Not sure from the pics,but bores look like a +/- 0.05 mm wear.Also no honing marks?
              • orignalS60
                • Mar 2015
                • 792
                • Home: Croatia Current: United States
                The marks are only on the area where
                your valves go over the pistons. The valve
                relief area. I'd say your valves have just been
                kissing the top of your pistons. Not that bad
                though. When I over revved a 2.7t motor
                the tops of the pistons looked like swiss cheese.
                • pasbogdan
                  • Sep 2009
                  • 1160
                  • Country: Romania
                  Looking closer you will see that damaged area is near valve relief area.On intake valves.
                  • Thuppu
                    • 4115
                    BTW pop, for how long have you been running on e85? I'm just thinking of the sooth/carbon build on your pistons... there shouldn't bee any with e85. Does the engine burn oil?
                    With e85 it is quite easy to tune the timing over the MBT limit without any knock. The cylinder pressure can destroy the engine before you can register knock. Also the carbon build on your pistons can act like a spark plug and you will get pre-ignition(also too warm spark plugs are bad), and too agressive timing will do it worse. It's difficult to tune full potential of e85 without a brake dyno, because on road it's really hard to tell when the engine stops to make power(whitch is the timing limit) or starting to drop power.
                    • quattrostyle
                      • Oct 2006
                      • 6229
                      That's what I was thinking as well, cylinder walls seem too smooth?
                      • popdemonic
                        • Dec 2007
                        • 1304
                        • Country: Thailand
                        Thomas,
                        the reason i popped up the head due to the engine is burning some oil when start up.i guess the valve guides are shot or
                        the oil from the breather issue i been posting right here for a numerous times.the carbon deposits on the top of pistons is motor oil indeed.
                        i've been running on E85 for nearly 4 years.For some reasons that coming into my mind 1.last 2 weeks on the way home i couldn't find
                        E85 at the gas stations so i needed to fill it with E20 2.the ignition table is way too aggressive.this time i will be hundred times more careful
                        on playing with Ignition timing(Lesson learn).I will need to pay for a dyno tuning.on road tuning,we couldn't find any free roads to do the log
                        files tuning in Bangkok ,Thailand.we are infamous one of the high traffic in the world.Any guidelines on playing around with igniton tuning Thomas?
                        Thanks,
                        pop
                        • popdemonic
                          • Dec 2007
                          • 1304
                          • Country: Thailand
                          Patrick,
                          you meant the crosshatches on the walls?
                          • popdemonic
                            • Dec 2007
                            • 1304
                            • Country: Thailand
                            some updated!
                            got all the pistons out today.I'm checking for some any damages.Fortunately,the rest of the parts is fine.Only a light scored cylinder #3
                            i feel some lightly groove at the bottom of the scored mark line.uptop and middle is smooth.i'm thinking to leave it there and use it.
                            2 weeks ago all compression readings was 160psi.might be considering another AAN and preparing for swap when the right time has come.
                            the bearings on 5rods seems perfect.none of any scratches,seems they're still have plenty to go.
                            my sump baffle
                            It's superman's car.not sure some graphiti experts at the service shop did it.lol
                            • quattrostyle
                              • Oct 2006
                              • 6229
                              Yes, on the pics it looks like a mirror, don't know if that's just the picture though?
                              Also it won't explain the marks on the pistons but maybe explain why the pistons are kinda black?
