I pulled the AAN head off today.i planned to swap another rebuild head in.
unfortunately,i found there's a lot pitches on the top of #1 2 3 pistons as you
seen on the photos.the #3 is the worst volunteer.Can anyone help me investigate
if the top of the pistons damage due to some metal fell off or the Detonation did this.
my car is running on VEMS standalone and E85 biofuel.I occasionally heard some kinda
knock when WOT.i had been running 034 software back in the day and the knock noise
seems much more worsen but never got any pistons damaged just like this one.I checked the spark plugs,all is great shape.i still couldn't imagine if something could
fell off into the chamber.
piston#1
piston#2
piston#3
piston#4
piston#5
Head..
turbine wheel looks fine.
compressor wheel looks fine
ignition timing table.max boost is 270-280kpa.
piston#1
piston#2
piston#3
piston#4
piston#5
Head..
