If we discount the steering from the equation then we are left with a few ideas.
Apart from the viscosity, the only other tempearture dependent item in the oil system would be the thermostat built into the oil filter housing. Not sure how you can verify that without just feeling the pipes.
You have also disturbed the large temp sender which has the non return valve installed behind it. I am not sure what happens if that malfunctions or whether it could fail in a temperature dependent way. I know it largely to prevent drain back from the head but presumably the pump needs to work against it.
To be honest can't see what what cause the issue with the car just sitting. There has been a case recently of the oil pump drive loosing but that engine was subjected to excessive abuse far beyond normal operating conditions!
