Well, I have done one of the major upgrades to my S2 3B from 1992. I have installed a AAN ECU with TFSI red coils with no problems.
I will explain a little my experience to encourage someone that want to do it
I started to make an Excel sheet to make the conversion pins but I have many questions about Clima and others. Searching a little at forum I seen that it’s done by S2Central. My pin assignations are well and I solved my questions with this Excel file. So finally I have been guided with these proved info: S2Central 3B to ABY conversion.
I used these coils and loom to do it: Coils and harness 3B to ABY
I not made a pin change, I made a ECU pin converter. More work yeach but I’m a nerd
When I fitted the new TFSI red coils I need to drop the rubber and cut 1-2mm the plastic base to fit at 3B rocker cover.
Engine started at first key so I was so happy. ^_^
I find some differences from 3B ignition to ABY/AAN. First it’s more smooth, sounds better and… The engine feels to have more power/torque at low/mid RPM. It’s another car, more nervous and responsive. I’m very happy. (My ignition dizzy are new and with metallic gearwheel, good wires… so it was not failing).
I have some moods to do. I want to put AAN cam cover. Why? Here we have very restrictive vehicle inspection programs so I want to see my engine looks stock. I like not justify to an ignorant inspector what it is, why, etc…
Another mod to do is put ABY fuel rail with stock 4bar fuel regulator, stock AAN/ABY injectors. It will do soon as I have a flexible fuel line and regulator clip that I don’t have yet. The have all rest of needed parts. I do it to match 100% ECU fuel rates and improve fuel economy (4 holes vs one).
So… Questions!!:
Could put AAN cam cover with stock throttlebody and admission tube? It looks that tube will not fit with these cam cover…
Could TFSI red coils will dead soon if I don’t change DWELL value at ECU? Or are these more tolerant at original DWELL value?
Thanks in advance guys
So… Questions!!:
