Hi guys. I am still having troubles with my UrS4, and I have ran out of ideas completely.
She's Stage 1 chipped, so she should boost to 2.5 bar, but she will only do 2.3 bar. It's not just the lack of boost. She is very sluggish and heavy, and not responsive enough. Around town it is pretty hard to drive, as I need to push pretty hard to get some momentum. Fuel economy is about 14mpg (doesn't change much if I drive her hard). Idle is perfect, smooth, no shakes or misfires.
Things that I have checked so far.
Boost test - No leaks.
MAF - New
Knock sensors - New (torqued correctly)
Exhaust - checked for blockage
Timing - Checked and correct.
TPS - Checked
Lambda - New
Filters - all new
Vacuum lines - triple checked
FPR - checked
Can't connect vagcom atm, as win10 is being a little bitch. I will try and order reader off ebay. But this problem has been going on since engine work that was done over summer, but engine has been out again since and everything is top notch.
I do want to thank John (newsh) as he's been helping me out tons, since I got my red S4. Without him I think my car would be in the local scrap yard.
John suggested possibly MAP sensor is faulty, anyone have experienced faulty MAP sensor?
Also, is anyone around Leeds and could lend me ECU to try in my car and see if that fixes the problem?
Thanks in advance.
MAF - New
TPS - Checked
Lambda - New
Filters - all new
FPR - checked
Thanks in advance.
