I have a 92.8 stroker in an AAT tall deck.
After much research, I decided it was the way to go (largely) based on its favourable rod ratios. If I decide to rev high and often, it should (in theory) be reliable. However, by all accounts, the 95.5 crank is good up to 8,000 rpm.
Considering the stock oil pump is good to 8,500 rpm, you're not gaining much with the unicorn crank. For me to consistently rev over the oil pump's capacity, I'll need to revisit the head with solid lifters, full valve train and go to dry sump for the oiling.
