92.8mm Crank for stroker
  • rynaqui
    • Mar 2012
    • 2752
    • Country: Malta
    I'm starting to think about an engine rebuild and was thinking of going for more displacement.
    I'm interested in a 92.8mm crank, specifically this one by FRP http://fourringperformance.com/crankshaft.php
    What kind of displacement can I achieve combined with an 82.5mm piston with the stock block and what sort of rod length would be suitable?
    I'm not very familiar with building engines so any guidance and advice would be great as there is no support for 5 cylinder Audis in Malta at all
    1996 S2 ABY Silver
  • Kieron20V
    • Mar 2008
    • 1505
    82.5/2 = 41.25
    (41.25^2 x 3.142)x92.8 x 5 = 2480cc ~ 2.5L
    Sent from apollo 13 using tapatalk
    1994 URS4 Avant RS2+
      AndyP has built a striker with this crank, so check his thread out. To fit in a stock block you need either shorter rods or different pistons.
      A stroker will require a new turbo and all the associated gubbins plus a custom map.
      • Kieron20V
        • Mar 2008
        • 1505
        Andy's was a tall deck block if I'm not mistaken?
        You'll need custom length non standard rods if you want to use standard comp height pistons, or you'll need custom pistons to use standard 144mm rods.
        • rynaqui
          • Mar 2012
          • 2752
          • Country: Malta
          Yes I was planning on going for aftermarket rods and pistons just not sure what sizes I need to go to
          1996 S2 ABY Silver
          • FCP-ENGINEERING
            • Feb 2011
            • 173
            • Country: Lithuania
            If you want to fit this to standart height block aan or 7a you need 144mm rods and 9A turbo pistons. We have all this parts pistons 82.5mm or 83mm Woessner.
            All fits directly no modifications. PM for priceses.
            Audi S4 2.6 20V STROKER kkk26/27
            • rynaqui
              • Mar 2012
              • 2752
              • Country: Malta
              Thank you have sent you a message, sounds good to me
              1996 S2 ABY Silver
              • rxl
                • 1913
                if you go 82.5 Pistons you will Need a custom headgasket becouse stock one covers only upto 82,00
                • Thuppu
                  • 4115
                  The stock gasket can be modified to fit 82,5mm.
                    $3100 US for just the crank. Good luck.
                    That said, FRP = Jeff Gerner, the owner, builder and driver of the world's fastest sedan, a 92 UrS4 with 1039 hp. So that crank is going to be good.
                    Your one-stop-shop for high performance and racing engine design and construction.
                    • rxl
                      • 1913
                      you can order one for 1250 euro
                      • AndyP
                        • 6049
                        No he didn't!
                        Mine was done with the AEL block and crank at 95.5mm. If you want to do it using the stock block, just get a 95,5mm TDi crank and save yourself $2500.
                        • FCP-ENGINEERING
                          • Feb 2011
                          • 173
                          Yes TDi block with crank is bargain
                          • diesel des
                            • 3896
                            Tdi all the way...
                            • bluequattro
                              • 2960
                              I've an a6 2.5 tdi complete car
                              £350
