Turbo Refurbishment
  • neal1981
    • Jun 2015
    • 195
    Turbo Refurbishment
    Hi
    Is there anybody out there who can refurb turbo internals upgrade where possible?
    I have an Albert K26 hybrid that looks like it could do with the once over by somebody more qualified than me.
    I've spoken to a couple of online companies but they are talking £300 before they even take the thing apart, fr that money i may aswell take my chances & have it installed as it is.
    Any help will be greatly appreciated
    Kindest Regards
    Neal
  • SteveH
    • 4460
    Why would you want to rebuild a recently refurbed turbo? £300 is on the money for a strip and rebuild. The cost s due to the rebuilder wanting to replace seals/rings and rebalance before puting the unit back together for you.
    91 Modded 3B
    14 A6 Avant Black Edition
      what's wrong with it?
      • neal1981
        • Jun 2015
        • 195
        No the turbo hasn't been refurbished at all, I purchased the turbo off a member on here for £600. Thee doesn't appear to be damaged the compressor wheel doesn't spin & keep spinning for as easy or long as i imagined it to hence why i want it refurbed with new internals seals/rings and rebalance like you said.
        This is hole reason I'm asking on here Steve is to see if anybody can do it any cheaper.
        • Jaswan
          • Apr 2011
          • 765
          it dosent sound faulty to me, i have a ceramic ball bearing turbo and that only spins a little bit after giving it a "finger spin"
          is there any play in the shaft? why not just take it to a local place for them to have a look at it and advise?
          Jase.
          • Jaswan
            • Apr 2011
            • 765
            Also, i think the point made above is that Albert only produced these turbos quite recently so it was only rebuilt....what.. say a year ago? (correct me if i am wrong)
            Jase
            • twoqu
              • Sep 2003
              • 3103
              Its probably due to the fact that the centre housing is dry. The shaft and bearings need oil to float on.
              It will be a bit messy but if you pump some oil into the correct port, that should make things better.
              Not sure if its been used before or not, but as long as you are confident of its history then it should be good to go.
              To be honest its difficult to accurate assess problems off the vehicle unless you have the specs and accurate measuring equipment.
              • LHD_Kid
                • May 2006
                • 3696
                Might also be worth asking Albert?
                • K Simmonds
                  • Dec 2007
                  • 7627
                  £300 is the going rate for a strip and rebuild but for £600 I'd expect it to be in as new condition as per the photos, it doesn't appear to have been fitted let alone run so should be good to go.
                  As Twoqu says journal turbos rely on the shaft's bearing floating on a film of pressurised oil and it's probably just dried out a little due to the lack of storage bungs, by rights the oil and water feed/return ports should be blocked whilst not installed, the oil in particular.
                  The oil feed is the small hole on the top side of the centre section with an M6 stud either side the return is the larger hole on the bottom with an M6 threaded hole each side.
                  When installing the unit be sure to prime it with fresh oil before connecting the supply hose, I use a little funnel and manually spin the shaft to ensure it's lubricated ready for start up.
                  Is there any side to side play or end float?
                  1990 B3 2.0 80 quattro.
                  1992 C4 2.8 Avant quattro
                  1994 MTM RS2.
                  1998 B5 TDI quattro Sport.
                  2000 B5 TQS.
                  • craigs4
                    • Jun 2009
                    • 129
                    Turbo Experts
                    Hi All , Just A Quick Message To Inform Everyone Myself And Family Are Just About To Open Are Turbo Company, We Are Based In Matchams Ringwood And Are Very Highly Experienced With Turbos , Many Of The Later Hoffer Turbos Where Built By Myself And Produced Great Results, We Can Offer Advise , Repairs , Upgrades And Rebuilds And Even A Fitting Service . Unlike Most Other Turbo Companys Out There We Aim To Be Helpful And Be Very Realistic With Pricing . The Other Great News For You Guys On Here Is We Love Are Audis And Have Great Experience With Them And Good Advise For Older Models As Well As Newer Models. Within A Few Weeks We Will Be Fully Running So Will Keep You All Posted :d
                    • K Simmonds
                      • Dec 2007
                      • 7627
                      That sounds great, it'll be good to have a resident specialist on here so to speak, the Hoffer turbos were well regarded and very fairly priced IMO.
                      Interesting use of capital letters by the way...
                      1994 MTM RS2.
                      2000 B5 TQS.
                      • cardcrash
                        • Oct 2009
                        • 763
                        • Home: England Current: Wales
                        Yes my grammatical OCD spotted that, along with two cases of "our" being spelt "Are"
                        Won't hold it against you.
                        Edit: Good luck with your new enterprise
                        RS2 - Project Mental Wheels
                        RS2 - LHD on the road again
                        RS2 - reduced to component parts
                        RS2 Saloon replica
                        A4 1.8T
                        BMW 320d Touring M Sport Business Edition auto
                        • jogi730
                          • 2335
                          I even checked to see if the capital letters spelt something in code .
                          T W E N T Y F I V E P E R C E N T O P E N I N G
                          O F F E R T O F O R U M M E M B E R S
                          One can dream
                          Good luck with venture
                          Audi 90 quattro (Typ 85)
                          20v turbo conversion
                          • neal1981
                            • Jun 2015
                            • 195
                            Ok yeah cheers guys.
                            • SteveH
                              • 4460
                              Keep us informed Craig, you did a great job with the last turbo you rebuilt for me
                              91 Modded 3B
