max boost on my engine with a gt3582r
  • blackS2
    • Apr 2010
    • 455
    Originally posted by GazzaG60
    id suspect too little timing at high rpm. can you not get more in?
    I was running 25.5 deg at 6000rpm and 280kPa...
    [__]=oooo=[__]
    • diesel des
      • 3896
      #32
      That's a lot of timing. Odd.
      • V6quattro
        • Sep 2008
        • 949
        Originally posted by blackS2
        As I remember from BITBURG you are using E85?
        I dont know the reason but my EGTs went trough the roof when boosting higher than 1.8 at redline...
        I'm running E85 yes.
        My values @ 4 gear, 7000rpm, 2.33bar, lambda 0.79 is 897°C
        1360kg/600Whp Avant 0-200km/h 9sec
        • blackS2
          • Apr 2010
          • 455
          nice
          what cams and head?
          (by the way, the mentioned EGT issue only exists on my own S2 ... all the other S2 cars I mapped on VEMS or Motronic are running without any issue )
          [__]=oooo=[__]
