best oil filters for S cars?
  • URSIMPO
    • Jul 2008
    • 431
    Is it best to go get filters from the dealers? Or there's Mann; Mahle, Bosch..
    Any recommendations?
    • 4754
    I get mine from the dealers,wouldn't want to risk it for a biscuit.
      Mann all the way - they are the OEM
      • A1QSHIP
        • Aug 2004
        • 975
        Only Mann.
        "Nulla tenaci invia est via"
        • Thuppu
          • 4115
          Just bought a couple of Mann filters. Have been using Bosch before without issues.
          • mcandmar
            • Apr 2004
            • 5118
            Mann, Mahle, or Bosch are all good. I always use Mann myself, which is what Audi supply with a markup.
            91CQ20v - Gone to a new home
            93UR-S4 - The Magic Carpet
            94S2Bus - The Emerald Express
            • vidar skotheim
              • Apr 2005
              • 566
              • Country: Norway
              the ones from some 1..8t ore 1.9tdi are much bigger
              • diesel des
                • 3896
                Yep I use the 2.5tdi ones on mine. Huge!
                • RichLV
                  • Mar 2015
                  • 872
                  • Country: Latvia
                  Knecht/Mahle OC264 if I'm not mistaken is what's on mine.
                  • GazzaG60
                    • 4133
                    ive used everthing from factory to halfords.
                    no probs with any. does look a bit iffy a halfords white filter under tube and big turbo though
                      Hi Des, do you happen to have a photo of it fitted or on the bench, or maybe a part number ?
                      Thanks either way.
                      • diesel des
                        • 3896
                        Will get a look at the weekend.
                          Thanks, no rush / pressure.
                          • mcandmar
                            • Apr 2004
                            • 5118
                            I would be wary of using other filters, physical fitment is only half of the story. I looked into the 719/5 and 719/30 versions before, the /5 being used in 10v 5cyl cars, and the /30 being used in 20v 5cyl cars. Both had the same physical dimensions, anti drain back valve, and the same rating of pressure relief valve. The difference was the filtration, the 20v versions filtered to a smaller micron level.
                            I don't know how a diesel filter compares to a petrol filter, but judging by how much soot contamination you see in diesel engines i doubt it filters any where near as well.
                            • Ficksy Heart
                              • Jan 2014
                              • 58
                              i have also test the oilfilter from the 2.5 tdi I5 but for me it was too big. same line like the underside of the oilpan. now i have the filter from Golf/rabbit MK III TDI, fits perfect
                              Audi UrS4 20VT Precision 6262, VEMS, CatCams, SOLD
                              VW T4 TDI Multivan
                              pleasure by pressure...
                              If you are not breaking parts, you're not going fast enough...
