I've not been able to shake a 2413 fault for sometime. I do seem to have a slightly lower mpg than I would expect and performance is down intermittently.
Reading the details on fault codes then I shoudl be looking at MAF/Fuel Pressure/Exhaust
MAF and lambda are new and newish respectively.
I cannot hear or see any exhaust leaks.
Process of elimination....
How/Can I test the fuel pressure?
Is there anything else out there that may cause symptoms and 2413.
(Apart from 2413!, but I’ve kind of learnt to live with it cos it causes me no probs?)
, have you actually check fuel pressure? I cleaned out and used my oil pressure tester but bear in mind it is relative to boost pressure cant remember the figures but i am sure they are somewhere about.
