Sat at the side of the road...
  • Fat Audi 80
    • 10547
    I am hoping for the best case scenario for you Andy...
    Steve
    The Perfectionist
    • alexx230
      • Mar 2015
      • 80
      • Country: Greece
      Awful... All the best to your bella
        Poxy luck.
        Selfish comment - Just concerned for myself rather than looking to throw stones, pun not intended, but if you were not running an under tray, would that have contributed to the cause ?
        Best wishes. Hopefully there's some sort of silver lining however small, even if you most likely cannot see it right now.
        • piotr
          • Jul 2012
          • 1470
          • Home: Poland Current: England
          Hope it wan't be that bad,good luck mate
          • LHD_Kid
            • May 2006
            • 3695
            #20
            Booger....
            Hope it's not as bad as you fear...
            Good luck
            • Cordoba16vt
              • Apr 2014
              • 182
              • Country: Bulgaria
              #21
              It is an interference engine - inlet valves are all bent - all eight of them, so it is a head off job.Sorry to say - I have been there too .
              • mike74
                • Apr 2014
                • 615
                nightmare
                  No undertray, haven't run one since it flew off at 120 in 2007
                  Belt was less than a year old.
                  For the belt to snap the timing cover and end up in the cambelt is something you just can't account for.
                  Will check compression but expecting it to be head off. At least all the bolts won't be seized as it was only built 4 months ago.
                  • Rikki Kitto
                    • Feb 2010
                    • 6276
                    Scary think I'll check my belts too, good luck fella
                    • andy10v
                      • 5996
                      That is really bad luck, very galling after just getting it back together after all the work.
                      I would be wary of running it, if it has a bent valve and you break the head off the valve you can easily damage the head, piston, block and turbo.
                      My mates car dropped a valve head, punched a hole in the top of the piston, mashed the head/valves, scored the bore and blew fragments out the exhaust.
                      You could do a compression test as that is less force, but for the cost of a head gasket I would probably just pull the head.
                      Sold ABY-stock
                        If it was "all" it would be 10, not 8 (5 x 2 = 10).
                        • Cordoba16vt
                          • Apr 2014
                          • 182
                          • Country: Bulgaria
                          #27
                          Sorry I've done it on 16vt as well
                          • Rikki Kitto
                            • Feb 2010
                            • 6276
                            Best place for belts TPS are back order for months
                              ABY Engine belts - Alternatives to OE.
                              The PS/PB pump V-belt seems to be a 034260849E. Might be a LUCAS 13AV1025L Ref Audi 034260849E -) 11€ 45
                              http://www.ebay.ca/itm/Audi-RS2-V5-C...-/131624629634
                              The multiribbed belt = 034903137B
                              Might be a SKF VKMV 4PK882 Ref Audi 034903137B -) 7€ 57
                              REFERENCE: http://audicollection.net/forum/view...hp?f=4&t=17815
                              With respect to the Cam timing belt:
                              OE (if available - rumoured to be NLA but might be with Audi Tradition):
                              AAN and ABY = 054109119H 151 tooth timing belt. (151 Z in Katespeak)
                              NM,7A and 3B = 054109119G "toothed belt" 147 teeth (not 151 for the 3B)
                              RS2 = 034109119C = 150 teeth according to the photo (not 148 as I once thought)
                              <img src="http://12v.org/urs/AAN3BandRS2TimingBelts.jpg">
                              After Market:
                              Gates PowerGrip 5269XS (151 tooth x 19 mm wide) (presumably the same as the OE product, just in a different package):
                              Photo courtesy of "Moggie" on the S2Forum
                              Continental CT515:
                              Thanks to "TyloPuP..katMAN" and "dustovich" for doing the digging on the Continental belt.
                                ONLY use Gates belts IMHO.
